Charging via USB-C connector
Latore14
Hi people. I just wondering whether I can use USB-C 3.2 connector in my PCS laptop (Elimina series) to charge the laptop with an external battery. I found some info. on google, it is possible to charge some newer laptops via USB-C but I`m not sure whether it works with PCspecialist laptops as well. Thanks for any answers:)
sarMed
Hi, I have the same question (mine seems to be USB-C 3.1, and I also have an Elimina latpop). I need to figure out a way to charge my computer on a long haul flight, as it seems it requires too much power even when it's not turned on (180 W). I tried powering through USB-C but doesn't work even when I'm at home - I also tried on a docking station and it did not power it. I'm guessing that the answer is in the question, but I'm hopeful there's a workaround...
Hiya, is this a pcspecialist device? Can you post your full specs from the order page?
Latore14
Yeah,I have figured out. There is no way how to charge this laptop alternatively. Only option is to change battery and use power safe mode,and battery saver,that way it holds about 4-8 hours, depends what you doing. I bought universal external battery with variable voltage and tried to change it the normal way through DC input connector but ,for some reason it did not work as expected and won't charge it properly.
Aza
Given how good the mods are, i'd still post your full specs.
If anything, they can give you a more detailed insight and a walk through of how to fix it would then be helpful for others that use the forum too should they have the same system
It really wouldnt surprise me if theres not a better alternative than the workaround youve put together... seems a bit heavy to handicap your system and using a battery that wasnt specifically designed for the laptop could have unintended consequences, and possibly even invalidate the warranty if it does actual damage....
sarMed
Hi, thank you all for the replies. These are the specs:
Chassis & Display Elimina Pro Series: 15.6" Matte QHD 165Hz sRGB 100% LED Widescreen (2560x1440)
Processor (CPU) Intel® CoreTM i7 Eight Core Processor 10870H (2.2GHz, 5.0GHz Turbo)
Memory (RAM) 32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
Graphics Card NVIDIA® GeForce® RTX 3060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1st M.2 SSD Drive 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
Memory Card Reader Integrated 3 in 1 Card Reader (Full Size SD / SDHC / SDXC)
AC Adaptor 1 x 180W AC Adaptor
Power Cable 1 x 1 Metre Cloverleaf UK Power Cable
Battery Elimina Pro Series Integrated 62WH Lithium Ion Battery
Sound Card 2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & Wireless GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
USB/Thunderbolt Options 1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 1 x USB 2.0 PORT
Keyboard Language ELIMINA PRO SERIES RGB BACKLIT UK KEYBOARD
Operating System Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
