Check this spec
Matija Popovic
Im planning to get my first pc and I am just wondering if those specs are good.
Thanks
COOLERMASTER MASTERBOX K500 ARGB GAMING CASE
Intel® Core™ i5 Six Core Processor i5-11600K (3.9 GHz) 12 MB Cache
ASUS® PRIME B560-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
12GB ASUS DUAL GEFORCE RTX 3060 - HDMI, DP, LHR
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW) (Special Offer)
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
2nd Storage Drive
Extra Case Fans
3x CoolerMaster SickleFlow 120 ARGB + Controller Kit
2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Bigfoot
What is your budget? What will you use if for? What monitor will you be pairing this with (make and model or resolution and refresh rate). Please include the configuration link, so that changes can be suggested.
