Compatibility and advice?
iBushay
Hey guys,
still looking to upgrade my graphics card and seeing a bit of hype on the gtx 660ti, but researching and looking at benchmark tests have given me some questions?
Reviews show that the card is about the same, if not a bit worse than Radeon HD 7870 and looking around it seems this card is also a bit cheaper?
Would this card work in my system?
If so what is the reason behind this card being cheaper? Is there perks to nvidia cards over these ones?
keynes
If your budget is still £300 I'd get the best graphics card available for that (a GTX 670 OC perhaps). If your motherboard supports crossfire you could consider the HD 7870 with the possibility to crossfire in the future.
