According to the configurator an RTX 2080 and RTX 2080 ti use the same power
Swapping the PSU to 550W gives the hard error:
Then switching to a 2080 ti says:
For those thinking that might be normal, one would usually expect to see significantly different power consumption, e.g.
PCSPECIALIST - Top Spec Custom PCs & Laptops Built to Order
Manufacturer of performance custom computers and laptops. Customise your ideal gaming PC or laptop using our advanced configurator.
www.pcspecialist.co.uk
We notice that you have selected a 550W power supply, but based on our calculations we recommend you change your selection to a 650W power supply because your computer could require up to 565W of power including a 20% allowance.
EVGA GeForce RTX 2060 XC Ultra 6 GB Review
EVGA's RTX 2060 XC Ultra is the company's flagship RTX 2060, priced at $379. It comes with the largest overclock of all RTX 2060 cards: 1830 MHz. You may also raise the board power limit to 217 W, which is almost the maximum capability of the 8-pin PCIe power input configuration.
www.techpowerup.com
