Connecting an LG Ultrafine 4K monitor with USB-C
RobLiv
Hi
I have a new Destian laptop. It has a USB-C port that says it provides DisplayPort 1.4 over USB 3.2 Gen 2. I'm trying to connect to an LG Ultrafine 4K monitor. This was bought for a Macbook originally, but I have seen online that you can connect them to Windows from DisplayPort with the right adapter. So I assumed this would work with DisplayPort over USB-C. I'm using the USB-C / thunderbolt cable that came with the monitor.
If I go into Settings / Displays it says a second monitor is connected, but the LG screen remains blank - whether I choose duplicate, extend, or Show only on 2.
In Advanced display settings it says:
Display 2: LG Ultrafine
Display 2: connected to NVIDIA GeForce RTX 3060 Laptop GPU
Display 2 isn't active
So it's recognising the monitor, and identifying it, but not displaying. Grateful for any pointers if anyone out there knows about this sort of thing!
thanks
Robin
Hi
thanks
Robin
Hiya, could you post your full specs from the order page please?
RobLiv
here goes
Showing Order Reference 2348282
Chassis & DisplayDestian Series: 15.6" Matte Full HD 240Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4)
Memory (RAM)64GB PCSpecialist PRO SODIMM DDR4 2666MHz (2 x 32GB)
Graphics CardNVIDIA® GeForce® RTX 3060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1st M.2 SSD Drive2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW)
Change to: 2TB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 7000MB/R, 5000MB/W)
AC Adaptor1 x 230W AC Adaptor
Power Cable1 x 1.5 Metre UK Power Cable (Kettle Lead)
BatteryDestian Series Detachable 6 Cell Lithium Ion Battery
Sound Card2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® AC-9260 M.2 (1.73Gbps, 802.11AC) +BT 5.0
USB/Thunderbolt Options1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
Keyboard Language15" DESTIAN SERIES UK KEYBOARD
Operating SystemWindows 11 Professional 64 Bit - inc. Single Licence [MUP-00005]
Windows Recovery MediaWindows 10/11 Multi-Language Recovery Image - Unlimited Downloads from Online Account
BrowserMicrosoft® Edge
Notebook MouseINTEGRATED 2 BUTTON TOUCHPAD MOUSE
WebcamINTEGRATED 1MP HD WEBCAM
Warranty3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Build TimeStandard Build - Approximately 2 to 4 working days
Detailed Specification
Dimensions & Weight
Dimensions (w x d x h)361mm x 258mm x 32.5mm
Weight2.7 kg
ColourGrey/Black
Chipset
Processor SupportAMD Ryzen™
Memory
Memory TypeSupports DDR4 3200MHz
Number of Modules2 x Modules
Maximum Supported Memory64GB
Hard Drive Capacity
Hard Drive Type1 x 7mm, 2.5" S-ATA HDD support
M.2 Port2 x M.2 2280 SSD Ports, 1 x WLAN M.2 2230
Display & Graphics
GraphicsChoice of graphics cards - refer to configurator.
Screen Size15.6 inch Widescreen
Native/Maximum Resolution1920 x 1080
Refresh Rate240Hz
NTSC72%
Audio
ChipsetHigh Definition Audio + SOUND BLASTER™ cinema 6
Channels2 channel HD Audio
Connections1 x 2-in-1 Audio Jack, 1 x Microphone Jack
SpeakersBuilt in two speakers
Integrated MicrophoneYes, Array Microphone
Communications
Wireless SupportWireless LAN 802.11ax/ac/b/g/n (M.2 Interface)
Bluetooth SupportBluetooth V5.0 module support
Webcam1.0 MP Webcam
Keyboard & Mouse
KeysMulti colour backlit isolated keyboard
Language SupportMulti-Language support
Pointing Device | Touchpad MouseBuilt in Multi GestureTouch pad
Backlit KeyboardYes
Memory Card ReaderN/A
Ports
LAN1 x RJ-45 jack
USB1 x USB 3.2 Gen 2 Port (Type C), 2 x USB 3.2 Gen 2 Ports, 1 x USB 2.0 Port
Display1 x HDMI, 1 x Mini DP, 1 x DP via USB-C
Microphone-IN1
Headphone-OUT1 x 2 in 1 Combi Jack (Microphone jack will be disabled when in use)
DC-in1
Battery & Power Lead
Battery Capacity4 cell Smart Lithium-Ion battery pack, 62WH
Typical Battery LifeUp to 2 Hours
Battery TypeDetachable
Power Lead & AC Adpater1 x Power Lead included with AC Adapter
Security
Fingerprint ScannerYes
Kensington LockYes
here goes
Dimensions & Weight
Weight2.7 kg
ColourGrey/Black
Chipset
Memory
Hard Drive Capacity
Display & Graphics
Refresh Rate240Hz
NTSC72%
Audio
Communications
Webcam1.0 MP Webcam
Keyboard & Mouse
Backlit KeyboardYes
Ports
LAN1 x RJ-45 jack
Microphone-IN1
DC-in1
Security
Kensington LockYes
The thunderbolt adapter you have won't be compatible with the USB C port.
USB C and thunderbolt are 2 different things, yours is a thunderbolt adapter rather than USB c.
RobLiv
Thanks. Yes, having done a bit of research, you're right, I ideally need to use the USB-C cable that came with the monitor (it came with that and the thunderbolt cable). Unfortunately I can't find it, so I'm buying a USB-C cable that says it supports monitors up to 4k @60hz, so hopefully that will do the trick.
