Control Center 3.0 GPU fan dial stuck at zero
Gage
Hi, I received my new laptop yesterday (17.3" Recoil) and installed the Control Center software. It was working fine and I could see the temp needles on the CPU and GPU moving according to what tasks I was doing. However today, the needle for the GPU temperature is not moving at all, even if I'm doing something more graphic intensive. I've attached a screenshot. Not sure what to do, so any advice would be appreciated.
Can you post your full spec please
Gage
H Bhuna50 specs below:
Windows 10
Recoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080) + G-Sync
Intel® Core™ i9 Eight-Core Processor i9-11900 (2.5GHz) 16MB Cache
Memory (RAM)32GB Corsair 2400MHz SODIMM DDR4 (2 x 16GB)
Graphics CardNVIDIA® GeForce® RTX 3080 - 16.0GB GDDR6 Video RAM - DirectX® 12.1
djsubtronic
Correct me if I am wrong, but the Recoil is a Tongfang chassis whereas you seem to be using the Clevo Control Centre.
Gage
I'm using the control center that was supplied by PC Specialist with the laptop, so I assume it's correct for this machine.
Windows 10
Can you post the entire specs please as per the link and not just a segment.
Have you installed your own Windows / or did you buy license?
Have you run all updates?
What has changed on your system / have you done since it worked to when it didnt work?
Thank you.
Gage
I received the laptop yesterday - windows was installed with the laptop. (I just had to go through the set up steps) I've just checked windows updates and there are some to do, so I'll sort that out and see what happens. I've only been setting up basics like colour theme, windows app permissions installing general programs etc., nothing techy that should affect fans or the software.
Full spec:
Chassis & DisplayRecoil Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080) + G-Sync
1st M.2 SSD Drive2TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 3000 MB/W)
2nd M.2 SSD Drive2TB CORSAIR MP400 NVMe PCIe M.2 SSD (up to 3480 MB/R, 3000 MB/W)
Memory Card ReaderIntegrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor2 x 280W AC Adaptor
Power Cable2 x 1 Metre UK Power Cable (Kettle Lead)
BatteryRecoil Series Detachable 8 Cell Lithium Ion Battery (97WH)
Sound Card2 Channel High Def. Audio + SoundBlaster™ Atlas & Super X-Fi
Bluetooth & WirelessGIGABIT LAN & KILLER™ Wi-Fi 6 AX1650 M.2 GAMING + BLUETOOTH 5.0
USB/Thunderbolt Options2 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
Keyboard LanguagePER-KEY RGB BACKLIT UK KEYBOARD
BrowserFirefox™
Its needed so that the techies on here can get the full picture of what they are giving advice on and in case something on here might be causing the issue albeit unlikely.
Can you go into Device manager and take a screen shot - are there any yellow warning triangles on any of the items or are there any items listed in Other Devices.
Can you also go into Windows Update and check that an update wasnt applied recently.
It seems odd that no updates are needed - as usually there are some to be run.(ah see that you have amended your post - yes you need to apply updates if there are some)
D
Deleted member 17413
Guest
You mentioned you hadnt done windows updates, thats a priority and your system isnt properly setup until it has.
When you are done with Windows updates, its still worth checking the Device manager. Also install HWMonitor and see what reading that is giving for the GPU
Gage
Thanks very much everyone for your help! I edited my post before the latest replies because there was in fact updates needed (sorry about the error there - I had checked before but didn't see any).
I've installed the updates and the GPU needle seems to be working again, so looks like that was what was needed. Seems so simple:) But I've not used this software before, so I've learnt something new:) I hope this post might be helpful to someone else in the future.
Thanks again, much appreciated:)
