i've got a problem with the Control Center (or GamingCenter) on my Recoil II.
It used to work fine, but since today morning i can't change the keyboard color and also i can't change the brightness.
The application works fine, but when i choose lighting settings it doesn't show up anything under Color Backlighting Wizard, but i can change the front bar color without any problem. After changing the bar color if i try to go back to the keyboard backlight wizard, the program crashes.
I've tried to uninstall the program and reinstall it without any success.
I've also tried uninstalling and reinstalling the OS but still doesn't work.
Does anybody knows what's the reason behind the problem and how to fix it?
Thanks in advance.
Thanks in advance.
