Cooler Master Side Panel
oli090
ive been looking into cases and ive chosen the t900 as it has leds and im childish so i think that it looks so sexy. i have also seen the coolermaster 310 with a side panel and LEDs inside. is it possible PCS that you could add a side panel in with LEDs? by side panel i mean like a clear peice in the middle :)
Corfate
I want a side panel for mine, but it's too late for me :(
They should be able to source one for you, and use it instead of the normal listed Coolermaster 310 case. Unless PCS see this thread (which im sure they will) you may need to ring up and speak to one of their call centre people, and ask if they can source you one, or you could buy one and ship it to them :)
oli090
ok so, i read that page and it says about make sure stuff fits. as its the same case you have but with a side panel does that mean it will fit?
PCS
Administrator
Staff member
Yes, base your specification on this and then everything will be fine. :)
