IRLRobinS
Hey all,
Hope this is the correct sub-forum, if not mods please move.
I took delivery of my 5900X build just before Christmas and while overall I was very pleased with my first PCS/Custom PC, one thing did annoy me: the case fans vs cooler fans, in terms of controlling both the RPM and RGB of each set of fans. Being new to RGB and AIOs, I had assumed that I could control all fans through a single application. How wrong was I! After fighting with iCUE, Amoury Crate, AI Suite and BIOS I was a bit frustrated, not to mention that the different applications did not play nice with each other so I eventually had to resort to a clean install of Windows and start from scratch.
I got to a somewhat steady equilibrium where AC controlled the case fans (3x 120 Cooler Master Sickleflow ARGBs that came with case) and iCUE controlled the three Corsair ML120s that came with the H150i Capellix AIO. But I still found that every so often AC would not work and the case fans would revert to the default alternating RGB pattern instead of the static blue colour I had set to match the AOI fans. That and AC's inability to set custom curves for fans made me decide quite quickly that the CoolerMaster fans would have to go and be replaced with Corsair fans that I could control via iCUE. The rear exhaust fan was a standard black DC fan, but I plan to replace that with a SilentWings 3 120 PWM version, again to provide more control over fan curve via BIOS. I also felt that the CoolerMaster fans perhaps ran louder than the Corsair fans.
Once I made this decision, I had to decide which Corsair fans to go for. The LL and QL fans certainly offer more RGB, but I felt that consistency of the RGB look was important to me, so I decided to go with ML120 Elites, which also have a higher RPM than say the LLs. It's worth noting that ML Elites have 8 LEDS, while the ML Pros have 4. I'm glad I spotted that or I would have had some very odd looking RGB effects. Originally I had tried to find the triple pack of ML120s on sale, but most retailers available to me were out of stock. I then realized that it would be cheaper to buy three single packs direct from Corsair, and the loss of the lighting node that comes with the triple wouldn't be an issue, as the Commander Core that came with the AOI had three free ports for the new fans.
So fast forward a week or so and the three Corsair ML120 Elites arrived today. And I managed to get them installed between my zoom calls
So to share some details on how I got on installing. Well the first thing I did was to plug them directly into the Commander Core and confirm they all worked. Didn't want to go through the entire process of removing existing fans, etc and then find out one of them was broken. Thankfully all worked out of the box:
One minor issue was how the CC was attached to the back of the case with cable ties: the lower cable tie blocked the last port, so had to cut that. It seems to be holding in place with just the top cable tie but I might replace the last tie with velcro backing tape once I've got most of the cable management sorted.
So the process of removing the existing fans was probably the most work. The front case cover comes off very easily, but thanks to some really good cable management by PCS, I had to snip a lot of the zip ties (around 14) to free the wires. Each CoolerMaster fan had two wires, once for the ARGB, that connected to a three way splitter than then connected to the ARGB header at the bottom of the mother board, and another wire connected to a three way splitter that connected to the CPU OPT header at the top of the motherboard.
It was at this point that I discovered that the CoolerMaster fans are not PWM as I expected but DC! An example of a manufacturer using cheaper versions of their retail fans in their cases, but probably goes some way to explain the higher noise levels, as there's less control on DC fans vs PWM, based on what I've researched.
The other challenge I faced in removing the fans was undoing all 12 screws attaching them to the case on the inside. Was quite cramped with the AIO and GPU in the way, but with the use of a short screwdriver I had just enough room to undo the screws. Would have been easier to remove GPU and AIO to have more space, but I was trying not to create work for myself.
Case with fans removed:
