Corsair 150i Middle fan running 2500RPM
Samuellofc
I recieved my desktop last week and the Middle fan is constantly running at 2500RPM, I have checked the QFan Control in BIOS, these are all set to quiet, from what I can see there is no Commander Pro installed in the chassis, so I cannot change the slot that it is plugged into either.
I have also changed all the fans and pump to quiet in the iCUE, but the middle fan which is set to fan 1 in iCUE but plugged into PCI Lead 2 is running really high RPM for no reason
Is this a PCSpecialist machine? Can you post your full specs from the order page?
Samuellofc
It is yes :) I should also add this is plugged into I believe the CPU_Fan port on the motherboard and not the CPU_OPT. The middle fan after being @ 2500RPM for45 minutes it is now not turning at all so is running at 0RPM
