Corsair 500D SE with Rear ML120 Pro RGB Fan fitted
Gavras
Master Poster
I eventually got round to sorting my rear fan out on my case.
Ordered a ML120 PRO RGB https://www.amazon.co.uk/Corsair-12...1610649230&sprefix=Ml120+,aps,156&sr=8-1&th=1
Not that fiddly, well apart from the damn screws lol, probably easier if I had removed a door lol.
Anyhow, Photos, at moment I don’t get to see much RGB as PC is sitting on left side of desk.
Definitely worth getting if you have the 500D SE.
The question is, will I go for LED Strips lol.
First photo, should be with door closed, while it is smoke glass you can still see RGB’s.
Obviously not for some but there is a Lights Off setting, the key reason is quality of fans.
melocolic
I've done the same as you apart from it being an LL to match the front 3. Brought a worthwhile drop in temps, especially when I had a Zotac 3090 in there for a while. Absolute no brainer for £20 or so.
Gavras
Master Poster
Yeah exactly, the LL is what I was tempted with and did have an initial bit of fun with ICUE not happy me shoving in an ML card with the other LL’s lol.
melocolic
Yep the LL syncs with the others as a group of 4 so didn't have any issues there. But as I've got ML's in the top the same as you some of the lighting profiles look a bit odd. Rainbow swirl looks great though. It's a great looking case and I'm pleased with it. The removable filters are really good too, I'm needing to clean them once a week on average and I haven't seen any dust inside the case itself yet.
Gavras
Master Poster
Yep it’s a great case, had mine since August, filters are a doddle.
By pushing it in to hardware mode and back out my fans are all reading fine and colours so far working fine, yeah some lighting profiles would take some living with
Definitely a nice drop in temps across the board.
keep my wine bottle cold.
