Park_Ranger
Hi guys, the front (200mm) fan has lost the will to live on my PC and I need to replace it.
I have tried to remove the front cover for access by removing both side panels, pressing the 6 clips to release the front cover, the cover comes loose all but the top left (looking from the front) corner where the power switch is.
Is there anything I'm missing at the back of the power switch or up in the top left hand corner.
It should be a very easy job, and I don't want to force it as it feels quite solid.
Any advice guys ?
Cheers.
Any advice guys ?
Cheers.
