Corsair H60 + Fan controller vs Corsair H80
Simrid
Hi guys,
Just after some opinoins on what is better; Corsair H60 & Fan controller or Corsair H80? I would like to know the noise factor and what cools better? (What allows bigger overclocks etc)
Thanks,
Simrid
tom_gr7
Life Serving
well the corsair h60 is pretty much the same as the h80, apart from a very minor things.
- H80 (also known as coolit fatboy) is much thicker and comes with two fans in push pull.
- h60 (coolit eco II) is just a normal rad with a single fan.
You should read this mate - http://www.frostytech.com/articleview.cfm?articleID=2664
Also, why do you say h60 plus a fan controller? You don't need a fan controller alongside a cpu cooler, unless you know what you are doing. Its much better to leave the CPU_fan/s to regulate its own speed.
Simrid
Hmmm, not sure which to get then? I mean the case i'm getting will have enough room, so what's the final verdict? :)
tom_gr7
Life Serving
looking at your specs in ya sig, you have a it 2400, non K, so with either cooler you cant overclock, well if you did it would likely cause the damage to the CPU. I thought of Overclockin my 2600 non K, but when I looked into its, its really not a good idea. So dont lol.
Cooling wise, I'd personally go for the h80, but use a good thermal paste (not the standard paste that is used) and I'd change the fans to match the theme of my case.
