Corsair ICUE 220T RBG Airflow Mid Tower Case
Oli_777
Not sure where I should ask this but,
does the Corsair ICUE 220T RBG Airflow Mid Tower Case come with a Lighting Node?
Yes.... from the bumf:
"Plug up to 6 of the same CORSAIR RGB fans directly into the included iCUE Lighting Node CORE to control your RGB lighting without the need for a fan hub, making for brilliant lighting effects right out of the box with CORSAIR iCUE software "
BlakeP
Hi, sorry to bump this. I ordered a pre-build with this case and I cant see the Lighting Node anywhere. When I go into the iCUE app it only shows that my motherboard is available to edit. Im unsure how to get the RGB fans working or if I have been provided with a lighting node
