I want to use the CORSAIR ICUE 220T RGB AIRFLOW Case which comes with "THREE INCLUDED SP120 RGB PRO FANS" at the front of the case, However I would also like to add extra fans so there's fans blowing air out as well. The only corsair fans listed are LL120 fans so I'm not sure if adding the 3x CORSAIR LL120 RGB FAN KIT will cause an issue since maybe the fans are not compatible with each other? This seems like a really silly question as i type it out but i'm not that tech savvy. I just want all the fans to be synced correctly. So I guess my question is, would the RGB actually work properly even though the fans are not the same model?
