Corsair Spec-Delta RGB Mid Tower Fan Lights
EasyLT
Hi. Just got my new pc delivered today. Everything works great except I can't find a way to change the colour on the case fans.
RGB Fusion 2.0 does nothing, Corsair iCue also doesn't detect the fans.
Please HELP!
Thanks in advance.
Full spec of the PC?
If it's a gigabyte motherboard, do you have the gigabyte app centre installed?
EasyLT
i7-9700k 3.6ghz
Gigabyte z390 UD
16 gb corsair vengeance ddr4 ram
8gb Nvidia Geforce rtx2070 super
And no, I don't have the app centre
The full spec. Which you can copy and paste from your PCS account. :)
Try installing the app centre since it's required for a lot of gigabyte utilities:
EasyLT
I installed the App Centre and Ambient LED and now I can control my fan colours.
But I also have LED strips inside. Do you know if there is a way to change their colour to match?
EasyLT
CaseCORSAIR SPEC-DELTA RGB MID TOWER GAMING CASE
Processor (CPU)Intel® Core™ i7 Eight Core Processor i7-9700K (3.6GHz) 12MB Cache
MotherboardGigabyte Z390 UD: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready
Memory (RAM)16GB Corsair VENGEANCE DDR4 2666MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1st Storage Drive2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE
1st M.2 SSD Drive1TB INTEL® 760p M.2 NVMe PCIe SSD (upto 3230MB/sR | 1625MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 550W VS SERIES™ VS-550 POWER SUPPLY
Processor CoolingPCS FrostFlow 120 Series RGB High Performance Liquid Cooler
LED Lighting2x 50cm Red LED Strip
Wireless/Wired Networking10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
Operating SystemGenuine Windows 10 Professional 64 Bit - inc. Single Licence
