CPU cooling system
joe1111
I just ordered the below. Quick question: Does it make sense to add a better CPU cooling system if I use this PC as a heavy number cruncher over extended periods of time?
Do I need to specify on which HD the OS needs to be installed? Do I need to specify what Graphic Cards I will put in?
Many thanks
COOLERMASTER SILEO 500 QUIET MID TOWER CASE
Intel® Core™i7 Quad Core Processor i7-950 (3.06GHz) 4.8GTs/8MB Cache
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
12GB KINGSTON HYPER-X TRI-DDR3 1600MHz, X.M.P (6 x 2GB KIT)
NONE, I ALREADY HAVE A GRAPHICS CARD ==>> 2x NVS295
Memory - 1st Hard Disk
120GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
2nd Hard Disk
1st DVD/BLU-RAY Drive
Power Supply & Case Cooling
CORSAIR 650W PSU (TX650) 80+ ULTRA QUIET (£76)
INTEL SOCKET LGA1366 STANDARD CPU COOLER
Network Facilities
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£109)
NO OFFICE SOFTWARE
Shibin
If your not overclocking and ur on a medicore budget just go for the super quiet cooler (£19). Best use for what ur doing.
PCS
Administrator
Staff member
1. The OS will be installed on the 1st hard drive.
2. You don't need to tell us what graphics card you plan to install, unless you want some re-assurance that it will work with the specification you have selected.
Nice spec you've ordered. :)
