Desktop advice for photo/video editing, 3D, and gaming | PCSPECIALIST
Arvind
Hello.
I'm new here and looking for a new PC to replace my current 11 1/2 yr old one.
I'll be using it mainly for Photoshop, Lightroom, Wondershare Filmora, possibly some games such as Death Stranding, and I want to start learning Blender (Blender requirements here). I'm not tech guy so don't really know the ins and outs of components, but I'd like to try and "future-proof" it somehow so I don't have to buy another PC in the near future.
I don't need a monitor. My current one is an Eizo ColourEdge CS2420 (see spec here). I don't need a cd/dvd/bluray driver either - I have Hitachi-LG USB 2.0 external DVD RW. My mouse is wireless (but I have a spare wired one as well) so needs a USB port for the receiver, as does my keyboard (wired). I already have anti-virus software.
Budget is around £1100 - £1400. Is that enough?? I don't know any other info you folks may need from me. Hopefully that's sufficient.
Thank you!
will the retiring pc be retired completely, if so you can transfer the windows over from that , which will save about £100 that can go into the build itself
Arvind
I did not know that was even possible! In that case it won't be retired completely. I'll also be taking out the hard drives and use them as a spare backup or something.
Explained here
Here you go this should do you
6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Standard Build - Approximately 14 to 17 working days
Price: £1,555.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/GGt39k8wqz/
Arvind
Thanks for this... Looks like a beast of a machine compared to what I have now! I may add some speakers as my Boston Acoustics seem a bit crackling sometimes - not sure if that's because of how old my PC is or not.
And thanks for that Windows licence link. Hopefully it's not too complicated a process.
Arvind
Hello again,
I have another question about compatibility. If I decide to choose a component of a different/higher spec in the list that @Martinr36 suggested above, how will I know if it's compatible with all the others? e.g. will it flag up on the website that "this processor is not compatible with the motherboard you selected", or "this graphics card isn't compatible with the processor"... or something?
Might be a stupid question, but are all the components/hardware compatible with each other?
Thanks!
Bigfoot
Hello again,
Thanks!
It is best to post the complete spec on here and you can get advice from someone who knows (and can explain their advice).
DarTon
I think switching from the 2060 to 3060 GPU for £21 is a no-brainer. Latest generation GPU, twice the VRAM and modest performance bump. You could downgrade from H115i to H100i cooler to save that money. Both are more than adequate for 5600X.
Agreed on the GPU, I think at the time I specced that there was a greater price differential, maybe the 3060 was out of stock, it was 2 months ago............................
David689
Hello again,
Thanks!
I believe the configurator, when you click on "proceed" will tell you if eg something you have selected won't fit in that case. But it won't tell you if that is an ill advised selection - if you post the full details on here then other users will tell you if you have made an ill advised choice. I have had some great advice on here - I had no idea about case and cooling. The options I chose were allowed by the configurator but when I posted on these forums some very helpful and knowledgeable folk told me that the case and cooler I had selected would not offer sufficient cooling and suggested alternatives so I went back and made alterations accordingly. I am now on day15 and waiting...
Hello again,
Thanks!
Define "compatible".... :)
If by compatible you mean will all the components you can select via the configurator work together, the answer is yes.
On the other hand, if by compatible you mean will all the components you can select via the configurator perform well together, or achieve their full potential, then the answer is no.
PCS will build what you order, and it will work. But to get the best performance within your budget you need advice on which mix of components to select. A build needs to be balanced so that each component is able to deliver maximum performance when operating in conjunction with every other component. That's what these forums are for, the experts on here understand how almost every component that PCS supply will work in conjunction with others and whether that combination will give you the best cost/benefit.
A build is not just the sum of its parts, there is so much more involved in getting the best bang for your buck. That's why you need to post the complete configuration you're considering (which you can do directly from the configurator) and the experts here will tell you whether you're making wise choices or not.
BTW. We can only discuss complete PCS builds on here, we're not able to give advice on components in isolation.
GidRea
I'm watching with great interest, as my situation is pretty much identical to Arvind's. I might clone the result :)
I'm keen to run dual monitors, as a screen calibration for photo editing is unhelpfully dim for general use. I see that the graphics card:
can run two or three monitors. But PCS have a special offer on the same card "DUAL", it's actually cheaper. But neither PCS website or NVIDIA tell this klutz what "DUAL" is, well, two of what? It's usually better to have two than one (monitors, ice creams...) - is it so in this instance?
If you create your own thread we can advise, it's best not to hijack other peoples.
Prices and components will have changed since this one was configured so we would likely suggest something different.
