Differences in power supply unit for a new PC
PeteScuff
After having had my current PCS desktop for nearly 10 years(!), it's time for a new one. The world of power supply seems to have advanced since I last looked, and I don't know what the differences / advantages are between the options. I'm give the choice of Corsair:
TX series
CV series
VS series
Is the TX a sensible investment for something I hope will last me years again? What's the difference between the CV and VS?
Spec below (and happy to hear of suggestions to improve). It's going to be in my front room and used for gaming and untaxing office work.
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
6GB NVIDIA GEFORCE GTX 1660 Ti - HDMI, DP - GeForce GTX VR Ready!
500GB Samsung 860 EVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
2nd Storage Drive
DVD/BLU-RAY Drive
NOT REQUIRED
STANDARD AMD CPU COOLER
Firefox™
Corsair are excellent regardless of spec to be honest. They are very well built, long lasting PSUs and have been for the time that I've known them involved in the market. Even their lowest spec cannot be compared to the unbranded trash that's available off the shelf so you can't really go wrong.
That being said, why would you stick a 1.0 eco boost engine into an M3. It's always different horses for different courses. The TXm is the normal recommended go-to for mid level systems. Anything involving gaming wants for clean reliable energy so the TXm would be my go-to in this instance.
Of course, buying this level of PSU isn't just about how efficient/powerful it is. It's also semi-modular (some of the cables can be removed completely for a neat install) and uses a premium cooling fan which is quieter than the bog standard options.
Onto your build, I would recommend a few changes....
RAM - You want it as fast as you can reasonably afford. The 3200Mhz is often the go-to but if it's not stretching you too much I would go for the 3600Mhz option.
GPU - As good as the 1660 Ti is, it's a hairs breadth better than the 1660 Super and considerably more expensive for this. The Super was brought out after the Ti and pretty much matches its spec while being cheaper. I would recommend selecting the 1660 as it's more than adequate and saves a few quid.
Storage - For your primary drive you want to select an M2 option, the SX6000 would be my normal go-to.
Everything else is exactly what I would recommend.
PS... if you include the link when you are copying the spec over it means we don't need to start from scratch..... eg..
DVD/BLU-RAY Drive
NOT REQUIRED
Price: £986.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/SWWdUHUxpd/
PeteScuff
Thanks Scott, much appreicated. Think the TXm makes sense, so I'll go with that. And use the money saved on the Super to get some better ram, and other suggestions. The 3600MHz is 21 quid more than the 3200 - would I see a noticable difference do you think?
Revised config
Personally I would spend it, it's one less thing to even consider as a bottle neck.
BTW, if your current system has Windows 10 on it, you can link it to your Microsoft account and then transfer to your new system for free. This would save around £100.
PeteScuff
Oh, that's interesting, and would definitely spring some cash. Do you have a link for how to link it to my MS account? Compelely unsure of how I'd go about it, if I haven't already.
