I'm having an issue with my PCS machine that I bought a good 7 years ago now and was wondering if anyone here would be able to offer assistance or suggestions as to what might be going wrong..
Basically whenever I push the power button on my PC the system appears to try and boot up and then immediately turns itself off again after roughly 2 seconds. If I leave it alone it continually does this for roughly 20 cycles.
I haven't changed anything in my computer for a long time and it hasn't been moved etc. recently in any way that I would think has caused this, so from my point of view it's fairly random. The only abnormality I experienced before this started happening was the system cut out randomly one night however after a reboot it was working fine again.
I've done a little research and I believe this behaviour is called "power cycling"? There's also a wide range of suggestions to check to see what could potentially be causing it. I am planning to open up my machine and have a look inside to see if there's any obvious issues however I thought I'd ask what you guys think could be causing it and potentially what I should be checking to solve the issue.
My PC specs are as follows:
CASE: Coolermaster CM Storm Trooper (Gaming Enthusiast Case)
CPU: Intel Core i7-4790k (4.0GHz) 8MB Cache
MB: ASUS Z97-A: ATX, UBS3.0, SATA 6GB/S, SLi, XFIRE
RAM: G.Skill F3-2400C11D-16GSR 16GB (2x8GB) 2400MHz CL11 DDR3-RAM 1.65v Memory Kit
GPU: MSI NVIDIA GEFORCE RTX 2060 SUPER GAMING X Graphics Card '8GB GDDR6, 1695Hz
HDD1: 250GB Samsung 840 EVO SSD, SATA 6Gb/s
HDD2: 1TB WD Caviar Black WD1003FZEX, SATA 6Gb/s, 64 MB cache (7200rpm)
PSU: Corsair 850W RM series modular 80 plus gold
Any insight would be greatly appreciated!
Cheers
Cheers
