Fan and Bracket lights not on
JazzyC
Not entirely sure what I have done, though fairly confident it is probably my fault...
New PC, delivered last week and setup over weekend. Weekend, all lights working no issue. Yesterday, the case fans and the GPU bracket lights were staying on even after shutdown. So turned off power at the plug as didn't want lights staying on.
This morning, those same lights are not on, and I cannot work out how to get them on. Fans are still spinning though.
Some more detail
In the iCue software, the cooler, pump and three other fans are all found. The mobo sometimes comes up but not always, but when it does the only thing I seem able to control is the LEDs (which I can't see). Since the start, neither the case fans or the bracket lights have been shown in iCue (but honestly not sure if they should do)
On the Gigabyte Control Center the only lights I can control are the RAM ones, which I also control with iCue. And the Firestorm software for the GPU allows me to control the ZotacGaming LED.
Of those 3 pieces of software, iCue is the only one that loads on boot, along with the Phillips Hue app (to control my Hue lights through iCue too). When I've loaded the Gigabyte Control Centre up after boot I often would get blue screen with DRIVER_POWER_STATE_FAILURE (or very similar at least). I attribute that to the Control Centre as PC runs fine whenever I didn't load that. So, I've subsequently uninstalled that Control Centre.
Pic attached just in case
JazzyC
Sure can;
CORSAIR 3500X ARGB TEMPERED GLASS MID-TOWER (WHITE)
Intel® Core™ i5 14-Core Processor i5-14600K (Up to 5.3GHz) 24MB Cache
GIGABYTE B760M AORUS ELITE X AX - WHITE (LGA1700, DDR5, PCIe 5.0, Wi-Fi 6E)
32GB Corsair VENGEANCE RGB DDR5 5200MHz (2 x 16GB) KIT - WHITE
12GB ZOTAC GEFORCE RTX 4070 SUPER Twin Edge OC - WHITE - HDMI, 3 x DP
Graphics Card Support Bracket
PCS ARGB GRAPHICS CARD SUPPORT BRACKET *WHITE*
1TB CORSAIR ELITE MP600 NVMe PCIe M.2 SSD (up to 7000 MB/R, 6200 MB/W)
1TB Samsung 870 EVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR iCUE H150i ELITE CAPELLIX XT RGB High Performance CPU Cooler - WHITE
Extra Case Fans
3 x Corsair ICUE LINK RX120 RGB PWM Fan + Controller Kit - WHITE
JazzyC
Apologies. Didn't think you'd also want to know what cabling I got with it too.
ONBOARD 2.5Gbe LAN PORT
NONE OR ONBOARD Wi-Fi (MOTHERBOARD DEPENDENT)
Change to: Windows 11 Home 64 Bit - inc. Single Licence
Firefox™
Monitor Cables
2 x 2m DisplayPort Cable - DP (M) to DP (M)
Miscellaneous
PCSpecialist 2023 Holo Sticker Sheet
Welcome Book
PCSpecialist Welcome Book
