fan making loud spinning noise
furkan
my fan has always been normal but last few days when i start up my computer it makes A LOT of sound and doesn't stop till i turn off the computer. sometimes when i restart the computer it fixes it but not always. any help would be great
Is this a PC specialist system?
What's the full spec?
Which fan makes the noise? The PC will have several fans in it.
You may need to take the side panel off the PC to hear better. And you can also visually inspect the fans to see if there's something caught in it.
Are you monitoring CPU and GPU temperatures? e.g. with something like Realtemp. If not, you should.
