Fan Or cooling suggestions
connay
Hi Guys,
Looking at getting some new case fans or some kind of cooling systems for my pc. The main thing I need cooling is my GPU as on high performance games it can get a little loud. Can anyone recommend any good ones? Not really got a budget for it as I'm guessing case fans aren't going to be massively expensive.
Thanks for any help, my specs are below.
Case PCS SR-620 MID TOWER CASE
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-7600 (3.5GHz) 6MB Cache
Motherboard ASUS® PRIME Z270-P: ATX, LG1151, USB 3.0, SATA 6GBs
Memory (RAM) 16GB Corsair VENGEANCE DDR4 2133MHz (2 x 8GB)
Graphics Card 8GB AMD RADEON™ RX 480 - HDMI, 3 x DP - DX® 12
1st Hard Disk 1TB WD BLACK 3.5" WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Power Supply CORSAIR 450W VS SERIES™ VS-450 POWER SUPPLY
Processor Cooling Noctua NH-U14S Ultra Quiet Performance CPU Cooler
Wireless/Wired Networking WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
USB Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
How many case fans are in there at the moment, and where are they positioned?
What model of RX 480 is it exactly? (you can use the lookup function on GPUz if you don't know https://www.techpowerup.com/gpuz/ )
What are the GPU's temps under heavy gaming load?
Have you dusted the inside of the PC? (if not, make sure you know how before you do :))
connay
2 case fans in there currently
https://www.asus.com/uk/Graphics-Cards/DUAL-RX480-O4G/ It's this card but 8gb version
I'm not sure about the temps but its never hot inside as the fans cool it well but its just that they have to go pretty fast which in turn makes them loud
I do clean it frequently but this has been an issue since I first got it so dust isn't a problem
Thanks for any help :)
I'd suggest checking the temps with something like MSI afterburner or Realtemp.
If the temps are a lot lower than they need to be and the GPU fans are too aggressive, you could just adjust the fan profile with MSI Afterburner.
