Fan rattle
Cavman
Hi all,
My laptop recently has started making a very faint, intermittent rattling noise and I have no idea why. It appears to just randomly happen, even if I'm just browsing the internet. It is just to the left of the touchpad on the chassis I think. I've seen elsewhere online that it might be a bearing in the fan but thought I would check here as well. I opened the back of the chassis to check if anything was loose or moving but couldn't find anything. Here are my specs in case they are needed.
Thanks.
Chassis & Display
Recoil Series: 15.6" Matte Full HD 60Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 8750H (2.2GHz, 4.1GHz Turbo)
16GB Corsair 2133MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1
1TB SEAGATE 7mm SERIAL ATA III 2.5" HARD DRIVE WITH 128MB CACHE (7,200rpm)
Integrated 2 in 1 Memory Card Reader (SD, MMC)
AC Adaptor
1 x 180W AC Adaptor
Battery
Recoil II Series 46WH Lithium Ion Battery
COOLER MASTER MASTERGEL MAKER THERMAL COMPOUND
2 Channel High Def. Audio + SoundBlaster™ Cinema
GIGABIT LAN & WIRELESS INTEL® AC-9260 M.2 (1.73Gbps, 802.11AC) +BT 5.0
1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 1 x USB 2.0 PORT
Keyboard Language
PER-KEY RGB BACKLIT UK MECHANICAL KEYBOARD
Firefox™
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Welcome Book
Logo Branding
PCSpecialist Logo
DarkPaladin
My initial reaction would be to check if the screws are fitted in enough. If the fan is rattling, it might be loose? If that isn't the case, try using your laptop for a short while with the bottom case removed until you can replicate or identify exactly what's happening.
TheMash
One of my fans on the Vyper III vibrates a little bit too. It's kind normal if it's faint, as it can produce some vibrations especially when it starts spinning from idle (the rotor moves a little bit during the start phase).
Touchpad on me was a bit too loose and I had to fix it with some paper spacers.
Cavman
Thank you for the replies. It seems to have settled a bit since it started. I'll try the suggestions. It's not affecting performance, was just annoying if I was watching something on my laptop.
