Hey guys hope you're all well/safe. I'm about to take the plunge and buy my first gaming PC. I currently have a PS4 which had been collecting dust for years until lockdown/WFH enabled me to dust it off and start gaming again. I'm thinking rather than purchase the PS5, I may as well go the grown up route and purchase a gaming PC (last game i played on a PC was the original counter-strike!).
I want to be able to play games like Warzone, Red Dead 2, Fallout 4 and have them look amazing at the same time use it as the PC i use for remoting in to work.
My budget is around £2,000 and after doing some research (and reading the excellent blogs on here about AMD vs Intel, I've come up with the below spec). I am quite unsure about certain components and would like your expert advice:
1) The case (I dont like the bright LEDs, want something understated but at the same time keep system temp down)
2) Cooling fan - is my selection adequate for case/other components
3) Power supply - is the power supply too large for my needs
4) Paste - I know its not much in terms of money but is it worth getting?
5) I havent got a gaming monitor as yet but will get one that can handle 1440/144hz refresh
Anyway, the spec is below. Is it overkill for my needs, do i need such a powerful CPU/GPU? Any advice would be really appreciated
Thanks
ASUS® TUF X570-PLUS GAMING WIFI (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler (AMD)
Extra Case Fans
1x 120mm Thermaltake TOUGHFAN 12 Case Fan
NOT REQUIRED
Standard Build - Approximately 18 to 21 working days
Promotional Item
Get Battlefield 2042 with select GeForce RTX™ 30 Series GPUs
Price: £1,986.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/ETzKDUDe7X/
Thanks
Extra Case Fans
NOT REQUIRED
Promotional Item
