First time build help!
MikeyB145
Hi everyone, Im intending to get my first properly built pc and i dont really know an awful lot about most of it so looking for some advice on it all if possible.
My budget is probably around £1500 at most, maybe a little bit more if needed. I already have a monitor so its just the system im looking for.
I'm looking to be playing games such as cyberpunk on highest, flight sim at a good level and just some newer titles in higher settings if possible.
Ive looked at some of the prebuilt/suggested ones on here so any suggestions of any of them would be welcome also
Any help would be much appreciated. :)
JUNI0R
Heya! We'd be happy to sort something for you! What monitor have you got? (make and model or resolution and refresh rate would be ideal!) Knowing this will be super important for which graphics card to pick to pair with the build.
MikeyB145
Hi all, I'm intending to get my first properly built pc and i dont really know an awful lot about most of it so looking for some advice on it all if possible.
I've got this spec (i cant now remember how i got it last night now) but would this be a good build?
Looking to game newer games on high end and things like cyberpunk on highest.
I dont really want to go much higher in price than this and obviously any thing to bring it down would be a bonus.
PCS SPECTRUM RGB MID TOWER CASE
AMD Ryzen 7 3800X Eight Core CPU (3.9GHz-4.5GHz/36MB CACHE/AM4)
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
Welcome Book
Price: £1,749.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/VV7yUXWgaV/
What's your monitor spec (resolution and refresh rate, or make and model) a few areas could do with some tweaks
JUNI0R
my monitor is MSI Optic g24 series. 144hz 1500r
For this monitor you wouldn't need to spend all of your budget, the 3060 will more than happily handle 1080p 144hz. You could spend your whole budget by upgrading to a 5800X system but it's not 100% neccesary. Up to you- we'd be happy to spec one for you if you'd like
COOLERMASTER MASTERBOX TD500 MESH ARGB GAMING CASE Better quality case with quieter fans, other options are the Lian Li Lancool II or Corsair 220T (which is quite small) or 4000X
AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4) Less cores but for gaming, performs better than the 3800X
16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB) AMD loves fast RAM so bumped it up to a 3200mhz kit
1TB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W) Swapped the SATA SSD for an NVME SSD
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET Much higher quality and higher wattage PSU which will comfortably handle a GPU upgrade when the time comes
Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] I'd personally stick with Windows 10 for now
Price: £1,500.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/UsgqwVw9u6/
MikeyB145
hmmm ok. I will have a think on that. thanks for the help :)
