First Time PC Build for Gaming/Academic Work | PCSPECIALIST
Macsmagic
First time custom PC customer here. Build would be for a combination of gaming and academic work using statistical analysis packages. There isn't a hard and fast budget per say but would like to keep the cost below €1800 if possible. Being a complete novice, I'd like some thoughts on any potential issues/faults that might be associated with the build below.
Primary Monitor is a AOC G2460PF 24" LED Full HD (1920x1080) Freesync 144Hz 1ms with an intention to add a 1440p monitor down the line.
NZXT H511 MID-TOWER GAMING CASE (WHITE)
ASUS® ROG STRIX B450-F GAMING (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1TB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
STANDARD AMD CPU COOLER
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Standard Build - Approximately 16 to 18 working days
Price: €1,558.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/Ba!NsDAgGz/
Thanks in advance!
sibun1
How far down the line would you be upgrading to a 1440p monitor?
If you are talking 6 months or so, then i would drop the GPU to a 1660 Ti for now....new GPUs are due in the next couple of months, a 2070 Super is likely to be much cheaper by the time you upgrade to a 1440p if its anything more than 3 or 4 months from now.
Would upgrade the WiFi to the AX200, much much better and a tiny increase in price, also comes with bluetooth that way.
Would consider a 550 motherboard, for future upgrade purposes (will extend the lifespan of the build by years as you will then be able to upgrade the CPU to the next generation (possibly even one after that)
a 3600X is fine with the standard cooler, i would recommend that you bought a better cooler with a 3700X or above
I would go something along these lines
AMD Ryzen 7 3800XT Eight Core CPU (4.7GHz/36MB CACHE/AM4)
6GB NVIDIA GEFORCE GTX 1660 Ti - HDMI, DP - GeForce GTX VR Ready!
1TB SEAGATE FIRECUDA 520 GEN 4 PCIe NVMe (up to 5000MB/R, 4400MB/W)
Price: £1,655.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/NUTvYWCn9e/
roughly 1825 euros, then when you upgrade to a 1440p all you have to do is swap out the GPU and you are good to go.
Macsmagic
Thanks for the reply, much appreciated! Yeah would likely be looking to upgrade to the 1440p in the next 6 months, so seems like a good call to swap out the GPU at that stage. Cheers for the feedback.
