Hi there, just after some advice. I have a fractual case and it is the type where you have a strip light for the power and that stays on constant and it flickers when hdd activity . The power light is now off, but i still get a flicker for hdd activity . I beleive i have chekced the connection plugs ok on the motherboard.
I also removed the front of the case slightly so could see connections and all looked ok as far as i could see. Does anyone know if there is separate led for these, so maybe one for the power has gone bad , or as i am thinking maybe the motherboard is not giving out the voltage on start up for the led and could be the start of motherboard issues that could require a rma
