Future-proof (relatively) gaming laptop - help/advice
D_Scim012
Hi all,
I've had my current PC Specialist laptop for about 8 years now and it's been great but time is finally catching up with it and the list of games that have to be played on the lowest of settings is getting longer. So, it is with some sadness but equal amounts of excitement I'm getting a new one. With help from the online chat team (thank you!!), I've so far got the following (see below).
Would massively appreciate help as to whether you think this would be a good set up for the price, and whether it will be somewhat future-proof (at least for the next 5 - 6 years). Any options that you think are or are not worth having would be particularly appreciated.
Treat me as a complete dummy, so feel free to go all in with the strength of advice/opinions.
Thanks in advance everyone! :)
Chassis & Display
Vyper Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2080 SUPER Max-Q - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 230W AC Adaptor
Battery
Vyper Series Integrated 91WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
1 x THUNDERBOLT 3 PORT + 3 x USB 3.1 PORTS
Keyboard Language
VYPER 17 SERIES RGB BACKLIT UK KEYBOARD
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Home Installation
NONE
Dead Pixel Guarantee
Chassis
TongFang GM7MQ8P (8GB RTX-2080 MAX Q, i7-10875H, 144Hz, Blank KB)
Price: £2,288.00 including VAT and Delivery
GeorgeCA
I have a Vyper with 2070 (is better than the 2080) and 16 GB of ram (2x8) and i can run all new games on ultra. You only need more than 16 GB of RAM if you do video/audio editing... you will never use the RAM up to 32...
Is a very good laptop i am very happy.
So if you can change the video to 2070 or 2070 Super, that will be good.
FerrariVie
Super Star
Sorry, but I don't agree that the 2070 super is better than the 2080 max-q. They are very similar and it would be a better value because it's cheaper, but if you want the absolute best and have the budget for it, the 2080 super max-q will give you a bit better performance:
Source
This video does not directly compare thermals, as the 2080 super Max-q in this case has liquid metal while the 2070 super is using normal paste, but due to the lower TDP, I also expect the 2080 to run cooler (I might be wrong, though).
briggm
View attachment 18481View attachment 18482View attachment 18483
Source
According to this comparison https://www.notebookcheck.net/GeFor...X-2070-Super-Mobile_10305_10229.247598.0.html
the 2070 comes out slightly better on average across a range of games.
Either way, they're both pretty close regardless. In favour of the 2080 Super Max-q is that it's providing similar performance for less wattage and like you said it may run cooler, however personally I couldn't justify the the extra cost of the 2080 over the 2070 Super. If it was a small amount ok, but we're talking about hundreds of pounds here.
Grumpywurzel
AMD would be a safer bet, plus it probably will work out a bit cheaper, or at least you will get a better CPU for your money.
32GB isnt needed for gaming and if it was then you would opt for the fastest RAM that you can afford.
GPU's in a laptop are a bit tricky, tend to be low power variants than a desktop plus as mentioned the super (mobile) vs the max-q can be confusing. Again a lot of this is down to budgets and I havent seen any mention of one.
barlew
Godlike
Hi all,
Chassis & Display
AC Adaptor
1 x 230W AC Adaptor
Battery
Keyboard Language
Keyboard & Mouse
Webcam
Home Installation
NONE
Chassis
I would recommend changing the the RAM to 16GB and the changing both m.2 ssds to 1TB PCS drives.
Also if you are planning on using the laptop extensively on battery power take a look at this thread before ordering: https://www.pcspecialist.co.uk/foru...le-performance-when-running-on-battery.72509/
barlew
Godlike
GPU's in a laptop are a bit tricky, tend to be low power variants than a desktop plus as mentioned the super (mobile) vs the max-q can be confusing. Again a lot of this is down to budgets and I haven't seen any mention of one.
You cannot get AMD CPU's in this laptop.
They would have to switch to a different chassis for AMD and then they would also have to settle for a lower spec GPU.
barlew
Godlike
Not in this particular chassis, so swap to a better one and slam the AMD in the thing?
Yeh that is a fair point, although it appears the maximum performance GPU PCS pair with an AMD CPU in a laptop is the 2070 in a Nova Ultra 15. This however is an entirely different beast its about twice the thickness of the Vyper with a small screen.
Personally I would prefer the Vyper with the 2080 Super Max-Q.
