Galaxy Case (blue neon LED tubes)
kazaam
I think this looks quite good. Shame it isn't stocked by pc-specialist:
Product Description
External Drive Bays: 4 x 5.25" and 2 x 3.5"
Internal Drive Bays: 4 x 3.5" H.D.D.
See Through Window Side+LED FAN
ATX Form Factor 12" x 10.5" or smaller
USB2.0 + AUDIO
Dimensions :410(H) X200(W) X 480(D) mm
Standard ATX 7 slots
ATX 12V 450 watts power supply included(20+4pin with SATA).
0.7mm SECC
bubble-Tube lights
PCS
Administrator
Staff member
It does look good in the pictures, but we've had these in stock before and the physical quality is not very high. The metal inside is sharp and "tinny" and the flaps on the front are easy to break off.
However, if you really like the case we can build your system into it using our "choose your own case" service.
kazaam
I like it but don't think I'd buy it for a home-use PC to be honest. It is a bit "too bare"
Thanks for the reply, some of the reviews for this case did mention poor build quality.
alefri
Hi, my first post here but I had to reply as you posted a picture of my current case.
I have a nice spec PC but the worst thing about it is this case really. I really liked the look of it before I knew my PC cases but after having had it for 8 months I have experienced what it is like to own it.
It will be the first thing I change on my PC, the case gets too hot, as mentioned already it is not the best quality, It also gets really dusty and the supplied LED fan is pretty shocking too.
On the plus side its cheap from ebuyer but im sure it would be worth spending an extra £20 and you would get a much better case.
Gorman
Yup a classic case of form over function, im not a fan.
LDUK
Master Poster
This was my old case. I highly advise people not to get this. It sucks, poor build qulity, and terrible air flow.
