Gaming build help
Jrh123
Trying to configure a gaming pc build and need some opinions. This is coming out at £1800 which is the budget I’m aiming for. My monitor is a BENQ - EL2870U. Any help would be appreciated!
FRACTAL MESHIFY 2 COMPACT BLACK GAMING CASE (Window)
Intel® Core™ i5 10-Core Processor i5-12600K (3.7GHz) 20MB Cache
GIGABYTE Z690 AORUS ELITE DDR4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
250GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 2300MB/W)
CORSAIR 750W CX-M Series™ SEMI-MODULAR 80 PLUS® BRONZE
Corsair iCUE H100i RGB PRO XT Hydro Series High Performance CPU Cooler
Windows 11 Home 64 Bit - inc. Single Licence [KK3-00027]
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/zK!45BPHSK/
budgie
Others have far more expertise than me, but...
16GB of RAM is normally enough for gaming so unlikely to need 32GB unless playing flight sims
500GB primary drive for OS is normally recommended, so that it's kept below half full for maximum efficiency
850W RMx PSU, or even 1000W if you can stretch to it - CX series is more budget build
Don't need the additional thermal paste, the Corsair coolers come with good quality paste
Jrh123
Thank you for the advice! I will be playing flight sims, hence the 32GB. With those changes you’ve suggested is there anything else that would be done to get the most out of my budget or is the spec okay?
Alltruism
That's a 4k monitor I think, and a 3060 GPU is more suited for 1080p gaming.
But if you're playing older games and happy to run them (or render them) at 1080p it might be ok.
If you're wanting 4k gaming it might be worth downgrading the CPU and upping the GPU a bit. Switching to the KF version of the CPU saves you £30 if you don't need the integrated graphics.
Intel® Core™ i5 10-Core Processor i5-12600KF (3.7GHz) 20MB Cache
ASUS® TUF GAMING Z690-PLUS WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP, LHR
Corsair H100x Hydro Series High Performance CPU Cooler
Price: £1,828.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/8MCeh8D6zw/
Jrh123
I think I’m going to up my budget and invest that into the GPU. Is there much difference between the K and the KF CPU’s for gaming?
