General questions
bigmaraippo
I called PC Specialist and asked them as to why the cable management was the way it was because I am myself completely unable to screw back on the cable cover so now I cant even put on the glass side panel! They simply said its because this case is a difficult one for cable management regarding my build..
Guys what are my options now? The cover is hanging out a little bit as you can see here so I cannot physically press the glass side panel to push it in. Even if I take the cover off, the glass panel has a little bit of pressure from being pressed on by the cables.
My main question here is can I leave the PC without a glass panel on the side of the cables? Will this affect the temperature in the PC on the other side? And what would be the best option to cover it for dust protection?
Sorry guys..
bigmaraippo
Hey guys,
My PSU; Corsair RM1000x as well as my PC are pretty much new and just recently I noticed that the psu has this buzzing sound going on which remains constant. Me being me, being a paranoid soul, I only discovered this by putting my ear next to the PSU. It is only noticable when putting my ear next to the PSU.
I notice this very low buzzing noise is costant when the PC is shutdown but when the PSU is switched on.
Is this normal?
Hey guys,
Is this normal?
It's absolutely normal, it's an electrical component, so there will be buzzing at very low volumes as the air escapes capacitors when it's cooling / heating up.
You are doing yourself no favours, you're looking for problems and causing some as a result. Just sit back and enjoy your computer.
bigmaraippo
Ok thank you..
Please bare in mind Spyder I hear this when the PC is turned off but the PSU is switched on!
For future reference, what are the signs in general that the PSU needs to be replaced? If the noise gets louder? sonically speaking.
Ok thank you..
You'd know it if there was an issue, the pc would fail to power on or it would squeel loudly.
It's very obvious when something isn't right on a PC.
There's absolutely nothing wrong with yours.
Just enjoy it.
bigmaraippo
Just enjoy it.
I hate to say it but I am only paranoid because it took two RMA's just for my PC to turn on..
First PC arrived damaged in regards to the top panel, glass was everywhere so they just replaced the case.
Second PC came with a new case but the same parts, I found glass shards underneath the GPU and the AIO pump was dead. Came to find out the GPU was scratched too..
So this is my third PC and I am only asking these questions because I never had a good start to begin with! PC Specialist have been nothing but supportive and I feel I just had a bad roll of the dice and it happens so!
Sorry to be a bother again Spyder but I just wanted to inform you that I enabled the erp settings in the bios to see if the noise would still occur once the PC was turned off and the noise was still there.
Does this mean that the noise is potentially an issue? or is it still a normal thing..
Regards,
I promise that if nothing else pops up then neither would I! Just learning my way with everything here..
Ok you've not mentioned any of that before
The PSU doesnt turn off when you shut down the PC, you have to flick the power switch on the PSU to turn it off
Modern PCs are never off, they just go into a low power state
It's perfectly normal.
RichLan564
Sorry guys..
Was the glass panel not fitted when it came from PCS??
bigmaraippo
Everything was fitted, although I did say to PCS that the welcome box shouldnt be pressing on the side on the top panel in the packaging, should have been next to the legs of the case. The DPD driver had some blame in my opinion too but hey here we are!
bigmaraippo
So that constant noise is normal even though the ERP is enabled? and that even when the PC is shut down and the power switch of the PSU is on, the buzzing noise is still normal?
Fingers crossed I have no issues!..Its been a rocky few weeks for me!...
If the PSU is buzzing when the switch on the PSU is off that likely means the power cable isn't properly inserted and it's arching. The PSU isn't active when it's switched off so theres zero power in it.
As said before it could just be the capacitors cooling.
I'm not sure what you mean by the ERP setting?
bigmaraippo
No no, the PSU is buzzing when the PSU switch is on; when the PC is shut off.
ERP mode is another name for a state of BIOS power management features that instructs the motherboard to turn off power to all system components, including USB and Ethernet ports meaning your connected devices will not charge while in a low power state.
The BIOS has no control over the PSU, the BIOS is part of the motherboard, PSU comes before that.
bigmaraippo
Okay but to conclude my issue..
A PSU that is switched on, close to ear, making the constant buzzing noise when the PC is shutdown..is safe to say its normal?
Last time I can say the same thing, yes, because it's not off. Any PSU makes noise at some level, pick up a laptop PSU or put your ear to the back of a monitor when it's on standby, it's completely normal
Insane.Pringle
got any hair left @SpyderTracks? given the number of way he phrased that question..
edit: i did find a gif of pulling hair out but i couldn't figure out how to embed it..:unsure:
Vajra
Negligence in the purest form. Shocking.
RichLan564
What’s that got to do with the glass panel not fitting ? So it fitted when it came from PCS so it should fit now.
