General questions
bigmaraippo
So recently I have noticed that I hear the sound of usb devices being disconnected and sometimes it follows the sound of a reconnection too.
So I installed USBDeview and I have found out which USB devices are causing this issue. The first two that are highlighted in blue.
I have no idea what devices these are.
Can somebody please give an explanation? I have read online forums stating it could be that the device is faulty or sometimes this is normal to get these pings.
Anything could help me here..Thank you
RichLan564
I see you are still looking for faults!
Is this during start up or during normal use ? Does anything stop working when it happens ?
bigmaraippo
Hey all,
I know I am seen here as ocd and looking for issues.
But just to own my first pc I have had to go through 3 RMA’s just to have a go at it after finally making the transition from console gaming..
First my pc arrived damaged with glass everywhere..the packaging arrived open at my doorstep.
Second RMA they replaced the case but I found glass shards dropping from the gpu, which damaged and chipped the gpu fans, the cpu cooler pump also had died. I had green lines going across the screen. Pc would take a couple reboots just to let me enter the password.
Third RMA I am here and my pc isn’t more than a month old. I loaded up warzone earlier this evening and I noticed a yellow artefact..which appeared for a second only.
Now I cannot upload videos here so I will share the link to where I’ve had it uploaded if the mods do not mind at all. -
Please note that this was the only moment I was able to capture from tonight. Last night I had red flickers coming and going as well.
Would this be compared to this symptom?
Can the mods please also not mix this with the general discussions thread because this is something completely different.. I am very sorry for always pestering but it’s because I’ve never had a fair start to begin with and now I’m always waking up to something potentially new to worry about!
RichLan564
Thank
You then.
Wasn’t the help I was looking for. Just delete this whole thread please.
The trouble is that people give you advice or ask you to check things and you never reply, you just come back with another unrelated problem, you have gone from temperatures of GPU's to PSU branding to cabling causing issues to USB disconnects to graphics artefacts.
I agree with @SpyderTracks if i was that unhappy or had that many problems with a PC (actual or perceived) i would talk to PCS in the first instance and return it if possible for a refund, then chalk it down to an unlucky/bad experience and move on and try to get a PC that i wanted to use without looking for every miniscule problem every time i turned it on.
This ^^^^^
Gary S
Hey all,
The yellow halo in your game coincides with the games direction legend changing to a distance legend readout at the top of the screen. This does not appear to be artefacting. It takes a lot of pushing to get GPU's to run into issues, and normally it will be sustained artefacting during an overclock.
I have read through the thread, and it looks like you had a bumpy start with PC gaming/ownership...but it seems now that you are OK and setup.
PC's are not as delicate as you may think (coming from consoles). The components are generally the best of their era - especially if a good specced machine for gaming etc.
bigmaraippo
Sorry are you referring to the moment the yellow flash appears at the 2nd second of the video?
I don’t understand the explanation regards to the legend readout you’re referring to. Because I haven’t seen anything of this sort from trying out warzone.
After this I will honestly be ok because I’m learning on the go. If you could please go into more detail as to what you explained I would appreciate it.
Thank you !
Thank you !
To me it looks like an error in Warzone itself, more than likely a weird glitch in the game. Not sure why you would be concerned about it not like these things don't happen in pretty much every game on every platform
Would only consider it an issue if it was constant/didn't go away
Gary S
Thank you !
Yes this yellow halo. Now if you look at the top of the screen where it tells you your orientation, North, South, East etc.....it changes from "S" or something and goes into distance in yards or meters or something. This happens at the exact same time as the flash of yellow on screen.
It's not an artefact, that's for sure. That's a deliberately drawn render, can tell by the shape and the smoothness of it. Artefacts are very glitchy and obvious. You sometimes get reversing of motion, but never a smoothly drawn semi-transparent spheroid.
bigmaraippo
Are you assuming that this has something to do with the game rather than the gpu? Because this has never happened before whilst playing this game.
