So basically I am getting a replacement graphics card, like for like which is a nvidia 3060 because my ones faulty but I wanted to know how to remove the card so I followed steps on YouTube to safely remove my one. So I did this no problem atall very easy but when I plugged it back in and turned the pc back on everything worked except the monitor (zowie 144hz) just says no signal detected? The pc is on, beeps once, fans are on, rgb lights are on but nothing to the monitor atall. Can someone help? Literally all I’ve done is remove the card the way I was supposed to and then reinsert it, plug it back in and power it on???
