mrdavidchapman
Hey
Thanks for any help anyone can give me.
I was posting some photos online when the screen suddenly went blank.
The PC appeared to be fine, it hadn't switched off. I restarted it and the monitor was coming back. Also, the graphics card fan started running fast and hasn't stopped since.
I had to plug my monitor into the default PC socket and the fan still runs fast as soon as I turn the PC on, so I guess its still getting power?
I tried to run a game to see if it would give me any indication of what could be wrong and threw out the below error.
Not sure if this is of any help.
specs are:
Specs are:
AMD ATHLON II X2 265 (3.30GHz/2MB CACHE/AM3)
ASUS® M4A78LT-M: mATX MAINBOARD, DDR3, USB 2.0, SATA 3.0Gb/s
1GB ATI RADEON™ HD 5750 PCI EXPRESS - DirectX® 11
Memory - 1st Hard Disk
640GB WD CAVIAR BLACK WD6402AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
Power Supply & Case Cooling
600W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan
STANDARD AMD CPU COOLER
Network Facilities
Genuine Windows 7 Home Premium 64 Bit
specs are:
Specs are:
Network Facilities
