Graphics card overheat after cleaning [Solved]
I have a P170HM (Vortex II) chasis with AMD HD6990M graphics. My system began to force shutdown due to overheat within 5 minutes of booting Windows 7 into normal mode. In one instance I managed to check the temperature before shutdown, which showed 103 degrees celsius. I have isolated the problem to the gpu when I ran checks on everything else in safe mode where the graphics card is disabled. The fan can be heard running normally.
This started immediately after I cleaned the heat sinks of the gpu and cpu recently (same procedure I'd done several times before without causing any problem). What could I have done to cause the gpu to overheat?
edit: it's probably a problem with poor contact, I'll replace the thermal paste tomorrow and report back .
