Gtx 970 heat
Adam262
This is probably me just being paranoid. I received my new PC Specialist computer yesterday and have been testing it out on lots of things. But one thing I have noticed is that when the computer is under a lot of graphical load, the fan goes really fast. The noise of the fan doesn't bother me, but I loaded up a GPU thermometer and it says that my Nvidia GTX 970 is 75-80 degrees Celsius when under load. Is this a dangerous heat level for it to be on. I will post the specs of my pc below:
Case InWIN G7 BRUSHED EFFECT DARK GREY CASE
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-4790 (3.6GHz) 8MB Cache
Motherboard ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
Memory (RAM) 8GB Kingston DUAL-DDR3 1600MHz (1 x 8GB)
Graphics Card 4GB NVIDIA GEFORCE GTX 970 - DVI, HDMI, mDP - 3D Vision Ready
2nd Graphics Card NONE
1st Hard Disk 120GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk 1TB WD BLACK WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
M.2 SSD Drive NONE
1st PCI-E SSD Drive NONE
2nd PCI-E SSD Drive NONE
RAID NONE
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply CORSAIR 550W VS SERIES™ VS-550 POWER SUPPLY
Processor Cooling Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler
keynes
It is not dangerous, they can reach temperatures closer to 100'C. To lower temperatures you could add more chassis fans and/or change the fan profile of your gpu
TheMightyChris901
I sometimes just change my fan manually depending on what game I am playing. If I am playing total war rome 2 I change it to 50%, and if I'm playing csgo I set it to 45% (stock speeds). The varying speeds of the fan can sometimes make whining sounds if I tab out so I prefer to leave it at one speed. If it starts to get to 85-90C I would RMA for overheating or you can turn your fans up with msi afterburner like I do. At 50% my temps never go over 75C. Hope this helps
TheGSL
I have a mini pc too, similar spec to your own slightly higher spec, on my 970 even on heavy load (Skyrim / Elite Dangerous turned up to 11) it never gets that high. Don't know if that helps. I would have a play with it all first before sending anything back, have a look inside to see if anything could be improved ventilation wise, is there enough of a gap around your case etc., are you next to a radiator etc.
