Guru Help Please £2k Spend.
KarlAggo
Hi All
Be very much appreciated if I could get a set of eyes on this build please.
It will mainly be used for Tarkov if I'm honest, but I would like to bring a little bit of my work home (graphic designer) if needed.
Would like to get the best I can around £2k mark ex vat as I can claim it back, there is a little head room above but only if absolutely necessary.
Thank you very much in advance guys 👍
Intel® Core™ i9 Ten-Core Processor i9-10850K (3.6GHz) 20MB Cache
ASUS® ROG STRIX Z590-F GAMING WIFI (LGA1200, USB 3.2, PCIe 4.0) - ARGB Ready
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
Corsair H100i RGB PRO XT Hydro Series High Performance CPU Cooler
Extra Case Fans
NOT REQUIRED
Price: £2,489.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z490-pc/GSUWjc9W7m/
KarlAggo
Hi Spyder
Yes we have had 2 PC's over the course of the last year (from PCS), however these were for work purposes and the boss bought them, this is for personal use and I will be paying, so my decision making is somewhat different.
Thanks for the reply.
Hi Spyder
Ah, cool, just double checking there wasn’t a problem with that one.
An AMD build would be far better overall, the 10th gen intels are 2 years old already. 11th gen perform worse than 10th and both are generally much poorer than a 5000 series AMD.
Especially when it comes to graphic design, AMD would be far superior.
KarlAggo
Ok Spyder, thank you, I don't want this to sound cheeky, but is it still a biased opinion on intel vs AMD or is that a proven 'it's better' as you say?
I know PCS will be eating turkey this Christmas the amount we are spending, but, the service and build quality has been fantastic, no better place to go. 😁
KarlAggo
Would this be more like it?
ASUS® ROG STRIX B450-F GAMING II (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
NOT REQUIRED
Price: £2,487.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/e5XSHNGQGv/
In multithreaded it’s not even close, Intel are years behind, they can’t even compete.
Your build will need some amendments, I’m currently a bit swamped with work, but will have a look later on. Someone else should be along to advise before then :)
I'll give it a go (based on suggestions I've seen previously, so please forgive any glaring errors)...
CORSAIR iCUE 465X RGB GAMING CASE - changed to a similarly sized case, but with 3 iCUE fans that you can control with the same software as the AIO and RAM - so less bloatware needed to control multiple provider's RGB kit
ASUS® STRIX B550-F GAMING (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! - more room for future upgrades, PCIe 4.0, USB 3.2 (the X570 may be better matched to the 5900x needs though)
32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 16GB) - don't see the need for 64GB unless you're doing video
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) - very fast boot/app drive
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) - great value game storage drive
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET - a bit more headroom for upgrades
Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler - changed to the newer/quieter Capellix version
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING - pre-applied paste that comes with the Corsair AIOs is better
NOT REQUIRED - not added one, so I assume you'll be wired at all times?
NO ANTI-VIRUS SOFTWARE - removed Bullguard as it's terrible
Price
: £2,495.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Muz!0GWxtE/
couple of tweaks to the @TonyCarter build above, the main one being upping the motherboard to the 570, and upped the cooler to the Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
NOT REQUIRED
Price: £2,578.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/CQ2Tc0!zsM/
