Help: 2400MHz RAM only running at 2133MHz? | PCSPECIALIST
Ashleyjames98
Hi again,
I've recently noticed that my 2400MHz Corsair Vengeance RAM is only running at 2133MHz. I'm aware that 2133MHz is the default but how do I go about increasing the speed to 2400MHz? This is my first form of OC'ing so any advice is greatly appreciated.
If it helps, My motherboard is a Gigabyte B450 Aorus Elite.
Many thanks :)
When you turn on the PC you need to enter the BIOS config screen. This is normally done via Del, F2, F10, F12 keys. There are others but it should prompt you on the screen as to which key to press.
Once in there you are looking for XMP settings. I'm not familiar with the BIOS screen for the Aorus Elite to help without a few pics but you may be able to figure it out from there. You want to enable the XMP profile of your RAM.
