Hello all,
Hopefully I have posted on the correct thread for this, I'm new.
Can somebody possibly please make a build for my requirements. I will be using Maya, 3DS Max, Substance Painter, Sketchup, Unreal engine and these kinda programmes, will be using rendering programmes a lot too.
I rarely play games but if I do it's usually only open world games (GTA, Cyberpunk, Star Citizen if it ever comes out) and would hope to play on high or near that. Additionally looking to use VR on it too in the future to bring some of my projects to life.
Would it be recommended that I get an M.2SSD for windows, an SSD for my programmes to store on and hard drive for the odd thing? Or is this over kill?
I'm looking to max spend around £2.2k-ish
Also any recommendations on a new monitor to go with it, not included in the pc's final price; preferably a 144hz monitor, IPS monitor. I'm looking at the "Acer Nitro VG270UP 27" WQHD 144Hz 1ms Gaming Monitor" at £350 has 144hz and IPS screen really cant go higher priced than £400. If this isn't recommended is there just a 144hz screen you recommend, without IPS?
This will be my first ever build so need some help
Thanks for your time.
