Help building gaming laptop
Need some advice on how to build the best possible gaming laptop (preferably using this site) but I have a budget of around £750-800 ($1214-1295). Fairly new to Pc gaming and was wondering if someone could help me build a powerful machine with good graphics based on the budget I have. Thanks a lot:yes:
Kieranovicci
Teaz
Godlike
Welcome to the forum :)
This spec should be more than ample for most games for your budget:
Chassis & Display
Optimus Series: 15.6" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-3610QM (2.30GHz) 6MB
NVIDIA® GeForce® GT 650M - 1.0GB DDR5 Video RAM - DirectX® 11
Memory - Hard Disk
500GB SEAGATE MOMENTUS XT HYBRID, SATA 3 Gb/s, 32MB CACHE (7200 rpm)
DVD/BLU-RAY Drive
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® N135 802.11N (150Mbps) + BLUETOOTH
2 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
Battery
Optimus/Voyager Series 6 Cell Lithium-ION Battery (48.84WH)
Power Lead & Adaptor
1 x UK Power Lead & 120W AC Adaptor
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
Total: 770
Configure it here :)
Teaz
Godlike
You can opt for that option if you wish to gain some extra push with the upgraded gpu when playing games but it isn't by a huge margin. Unless you desire and want that extra boost in gaming then you can go for the upgrade.
