help check this spec please! - Vfx and Motion graphics work
NoFace
Hello! Ive got another thread but have since updated my specs from them after going through some more information. I wanted to make sure that I'm not cutting any corners, however that the build is balanced and nothing is overpowered or falls short where it doesn't need to be. my budget is 2500 at the highest.
This is to be used primarily for VFX and motion graphics work, using mainly Cinema 4D redshift, premier pro and after affects, Nuke, Blender, Unreal Engine and Houdini. I am hopping for this to carry me through the last few years of uni and into industry. Any advice would be appreciated!
FRACTAL POP SILENT CASE TG (BLACK)
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5)
ASUS® TUF GAMING B850-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE RGB DDR5 5200MHz CL40 (2 x 32GB)
16GB PNY NVIDIA RTX A4000 GDDR6, 6144 CUDA CORES - 4 x DP
1TB CORSAIR ELITE MP600 NVMe PCIe M.2 SSD (up to 7000 MB/R, 6200 MB/W)
2TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
CORSAIR 750W CX SERIES™ CX-750 POWER SUPPLY
ID-COOLING FROST X45 THERMAL PASTE APPLICATION
ONBOARD 2.5Gbe LAN PORT
NONE OR ONBOARD Wi-Fi (MOTHERBOARD DEPENDENT)
Price: £2,465.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/e3vxsR0ptd/
Hiya, it’s very good overall, there’s a couple of areas that could do with an adjustment.
What was your reasoning for that specific case? It’s not ideal for this level of build, if it was purely aesthetical we can find something more suitable, if it’s for the quietness, that limits options.
I'd say the case, PSU and cooler are under-specced, especially if you're expecting to run it flat out for hours rendering something.
I can't upgrade those components without breaking your £2500 budget...unless I swap out the workstation spec A4000 (with its 6000 CUDA cores) for the desktop RTX5070Ti (with it's 9000 CUDA cores)...
CORSAIR 3500X ARGB TEMPERED GLASS MID-TOWER (PCS)
16GB PALIT GEFORCE RTX 5070 Ti GAMINGPRO - HDMI, 3 x DP
CORSAIR 850W RMx SERIES™ ATX 3.1, MODULAR, CYBENETICS GOLD
CORSAIR NAUTILUS 360 RS ARGB HIGH PERFORMANCE CPU COOLER
Price: £2,464.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/K8KYUNZCZN/
