Help choosing Motherboard :)
heza121
Hi everyone,
I have been customising my new spec, and its looking pritty hardcore at the moment! haha :D But I have no idea about what im doing when it comes to choosing the motherboards.
I have picked out 3, which are: (All Asus' and from PCS)
- Maximus IV Extreme-Z
- SABERTOOTH P67
- P8Z68-V PRO
Which one would be best for my spec. I plan to have a 3 monitor set up, and im unsure as to which motherboard to have.
http://www.asus.com/Compare/ This is a link to ASUS website where it shows the three different motherboards, but the information is too confusing for me. :D Comparison (click)
I have posted my spec below just in case you need to see that! All advice and help is greatly appreciated! Many thanks. :) :)
My Spec:
CORSAIR CARBIDE SERIES™ 500R WHITE MID TOWER CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V PRO: USB 3.0, SATA 6GB/s, NVIDIA®SLI™, ATI®CrossFireX™
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd Graphics Card
Memory - 1st Hard Disk
120GB KINGSTON HYPERX SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk
2TB WD CAVIAR BLACK WD2002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
3rd Hard Disk
3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
1st DVD/BLU-RAY Drive
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£79)
CORSAIR 1050W PRO SERIES™ HX1050-80 PLUS® SILVER MODULAR (£162)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19)
Network Facilities
ONBOARD GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI-E CARD (£16)
4 PORT USB 2.0 INTERNAL PCI CARD + STANDARD USB PORTS
Microsoft® Office Home & Student 2010 (1 License Product Key Card) (£82)
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£139)
2nd Monitor
3rd Monitor
Webcam
Logitech® HD Webcam C510 - 720p HD Video, 8 Megapixel Photos (£35)
Surge Protection
6 Socket Compact 2M UFO Surge Protector (£9)
Cable Tidy
JML 1.5M Zip Cable Tidy - Professional Cable Management For Your PC (£4)
PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON (£9)
Miscellaneous
FREE Battlefield 3 with 2nd Generation Intel® Core™ Processor-K
Quantity
1
Price: £2,615.00 including VAT and delivery.
Thanks again! :) ALSO ANY ADVICE ON THE SPEC IS GREATLY APPRECIATED AS WELL! HAHA THANKS! :D :)
heza121
Thanks guys, i did do some research myself into the motherboards, but i have very little knowledge in that sort of stuff. But from what i had read, the Maximus IV Extreme-z is best for overclocking. But again im not really too sure about that, haha. So hence why i had opted for the ASUS P8Z68-V PRO. :)
Oh haha, I think i will drop the extra USBs, lol! :D Thanks guys! ;)
heza121
Oh wow, haha, yeah i think i would have enough then, dropping the extra usbs, saving me about £15, thanks man! :)
tom_gr7
Life Serving
that's a beast of a spec dude,
only thing i would do, If you NEED the best, go for the titan fenrir. But check the case your getting can fit, look for "max cpu cooler height"
heza121
I couldnt find the "max CPU cooler height" :S but when i select the FENRIR and continue, it doesnt say that it wouldnt fit? or would this not tell me if i does or not? :S lol :p
tom_gr7
Life Serving
Ill have a search for ya dude,
but you dont NEED the titan, but if you want the best i would.
heza121
oh cheers dude!!! :D Much appreciated! :) I guess it wouldnt bee a bad idea, considering my spec haha :D
heza121
Ah thanks man, if the Fenrir does fit, will the case provide adequate cooling? :)
Thanks for the reviews tom, just reading them through now :D haha
tom_gr7
Life Serving
No worries, Just call up pcs to check that the side fan will not be removed if you go for the titan. I cant find the max cpu cooler height for the case anywhere.
its a good mid tower case, I noticed Its got very good cable management. But from reading the reviews there's few personal changes I'd make to the case. Like adding extra fans + fan controller, but I'd wait till you get the pc before thinking about customisation.
To answer your question it should keep everything nice and cool.
