Help Please
Hey guys just need some help. For my new pc I have chosen a Ryzen 7 3800xt and a rtx 2060 Super. Is this a decent combination or should i upgrade to the rtx 3060.
Many Thanks
JUNI0R
Many Thanks
Depends on a lot of factors, budget, what you're using it for, your monitor, the other parts in your build. If you supply us with that info we'll be able to assist you further
Here is my complete build, still not sure on some of the components. The pc is going to be mainly used for streaming+gaming. But overall im just not sure to use a 2060 super or 3060.
AMD Ryzen 7 3800XT Eight Core CPU (4.7GHz/36MB CACHE/AM4)
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP (Pre-Order Only)
2TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 128MB CACHE
CoolerMaster MasterLiquid Lite 120 High Performance Liquid Cooler
JUNI0R
This looks like a decent build, there's a few things I'd change but first we need to know budget and the monitor your using or plan to use (either make and model or resolution AND refresh rate). Also a configurable link and the price would be good to have too
I am currently using a 144hz monitor and I have a budget of £1700 and once again i appreciate your help.
JUNI0R
It is a 1440p
Fantastic! The 3060TI is a great card for your monitor!
If you're happy to go a little over budget by £30, here are some upgrades I'd recommend:
I'd remove the RGB ram and set it to standard 16gb 3200MHz 2x8GB sticks to save money
Change the 1st storage drive to the standard 2TB Seagate Barracuda
Upgrade the PSU to an RMx 750W (this will be more comfortable for your machine as the PSU will have to work less hard, which should extend the life of it. And it leaves some room for upgrades down the line
I'd change the Cooler Master 120 CPU cooler to 240
Upgrade the Wireless card to the 2nd option as it gives you both 2.4 and 5GHz wifi instead of just 2.4, and bluetooth for only £11 more
I'd remove the anti virus software if you haven't already as it's known to cause issues, and Windows Defender does a better job anyway
I'd also add the Silver Warranty for a fiver, well worth it
With those changes, you will have a great little build!
Standard Build - Approximately 12 to 15 working days
Price: £1,732.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/x90gpkcz6g/
Thank you so much i really appreciate it and it has helped me a lot. Many Thanks!!!!
JUNI0R
I've got another change you could make. If you play lots of AAA games that take up a lot of storage and you're nervous about filling the 500GB SSD up with windows, programs and games, is change it to a PCS 1TB M.2 SSD for only £3 more. It's a slower drive, but it's double the storage so will give you that extra piece of mind you won't run out of storage (if that's something you're concerned about). If you're playing older games or smaller file games, the 500GB will likely do just fine!
That would be absolutely perfect, thank you so much for the info it was very helpful
I'd actually upgrade that to the 850 as its only another £3...........
JUNI0R
This too! I find it crazy how minimal the price changes are between the higher end PSU’s and totally forget you can get another 100 watts for £3
