Monitor - I do not have one and am clueless as to which one(s) I should be considering, but it definitely can't be larger than 24"
Keyboard - Currently selected a SPCS BK110 USB
Mouse - Currently selected a PCS GM150 RGB Gaming Mouse
Speakers - NA (I only intend on using a headset)
Intended Port Usage - Headset and mouse/controller
Uses - Gaming (FPS, mobas, modded simulations, and new releases)
Budget - Up to £2,500-ish
Hi folks, I was tentatively navigating the options for a custom PC build before feeling a little bit overwhelmed, such as with trying to figure out what would be suitable choices for such things as motherboards, network cards, amount of ram, number of fans, and trying to understand whether I was right to ignore things like the option of a 2nd and even a 3rd graphics card(?). The amount of information made available in the '?' does feel comprehensive, but much of it is going over my head due to my obliviousess (I haven't had a desktop PC for over 20 years), even while consulting google for a couple of hours.
Any advice on what I ought to reconsider? Thank you.
PCSPECIALIST - Configure the Intel Z790 Ddr5 PC to your ideal requirements.
PCSpecialist is an award-winning manufacturer of high quality custom PCs & Laptops. Configure the Intel Z790 Ddr5 PC to your ideal requirements.
www.pcspecialist.co.uk
