I've reinstalled windows and drivers and it seems to be working ok but it says i've only 15gb of space left on c: which means i can't restore my files. I had masses of space before with all my files on it. Am I missing something simple?
Did you delete the drive before you reinstalled,
if not you may have a windows old folder on your system,
containing all the data from the previous install.
you can check this by opening the C drive,save the data you want then delete the folder.
Failing that look in disk management,right click "computer"/manage/disk management,
if there is unallocated space on the C drive right click on the drive & select extend.
Failing that do a clean install,make sure you delete the drive/partition before installing,instructions are given in the welcome booklet.
