Geostrong91
Hi guys, I need some advice with this pre build pc I want to buy, I don’t have weeks to wait for one that I can build, I want to start playing ASAP. I’ll use the pc for CSGO so I really need all the fps I can get, I play with this resolution 1024x768 and I’m planning to get a good 144hz monitor or a 240hz if I find a good budget one.
CPU: AMD Ryzen 7 2700x 3.7GHz up to 4.35GHz
Memory: 16GB Corsair Cengeance LPX 3000MHz
Hard drive: 240GB Corsair MP510 M.2 NVMe & 1TB Seagate BarraCuda
GPU: MSI RTX 2070 Ventus GP 8GB
Power Supply: 650W Corsair VS650
Motherboard: ASUS PRIME B450M-A
Cooling: ID Cooling SE-224C
Case: Corsair Carbide SPEC-Delta
The price for this pc is £1000 and its advertise that it can run CSGO at 257fps with 1980x1080, what do you guys thing? Thanks.
