Nafninja23
Hey guys, I bought my pc early 2012 and finally have a bit of money to upgrade a couple of components. Problem being I have no idea what's best to upgrade first without unbalancing the machine, whilst still getting a good upgrade. I'm likely going to purchase a ssd and second hdd as well (these seem needed) - so my main question is what do I upgrade now??? - probably can spend £200 - £300 atm, any advice appreciated
Spec ___
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics
ASUS® P8Z68-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
2GB AMD RADEON™ HD6950 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Memory -
1st Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk NONE
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19)
Fan Controller
NONE
GIGABIT LAN & WIRELESS 802.11N 300Mbps PCI CARD (£16)
Spec ___
Memory -
2nd Hard Disk NONE
Fan Controller
NONE
