Hey, Little Help please ?
Discharge
Heys people, new here.
Just wondering if this PC Spec will run the likes of TF2, MW2, BC2 and ME1/2
ANTEC 900 BLACK GAMING CASE (£79)
Intel® Pentium® DualCore G6950 (2.80GHz, 3MB Cache) + HD Graphics
ASUS® P7H55-M SI: MICRO ATX VALUE MAINBOARD,USB 2.0 & SATA 3.0Gb/s
1GB ATI RADEON™ HD 5850 PCI EXPRESS - DirectX® 11
Memory - 1st Hard Disk
500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
Power Supply & Case Cooling
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29)
Network Facilities
WIRELESS 802.11N 300Mbps PCI CARD (£16)
6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARDOperating System
Much Appreciated!
Gorman
Hello and Welcome,
Yes it will. If you have chosen that CPU due to budget restrictions i would consider going AMD as they offer more for the money at that price bracket.
Discharge
Thanks man!
okay, made some changes, what about:
AMD ATHLON II X4 640 (2.9GHz/2MB CACHE/AM3)
ASUS® M4A78LT-M LE: mATX MAINBOARD, DDR3, USB 2.0, SATA 3.0Gb/s
1GB ATI RADEON™ HD 5830 PCI EXPRESS - DirectX® 11
Network Facilities
4 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Thanks for the advice, thats a big £200 off!
Much Appreciated!!
Gorman
No problem, yes i like that spec. You could always plough some of that saved cash into the GPU, im thinking 5850.
Stappa
Hi I'd swap the 5830 back to the 5850 or a GTX 460? and poss pick a slightly better PSU depending on budget? I'm currently playing BF BC2/Napoleon TW on high/medhigh at 1680X1050 res with real good framerates and your purposed PC is better spec'd than my 3 1/2 year old gaming rig, you'll be fine:p
