High CPU temps
Emo
So, I think the problem was a missing ACPI Bridge driver that comes bundled with CCC. I installed this standalone, and so far the GPU has behaved OK for a couple of weeks.
Hi, I have your own laptop with your own problems, indeed I started OCT sessions that gave me very high temperatures (close to 100 for the CPU and 80 GPU). How did you solve?,
djsubtronic
No, where can I find it?
You should be able to log into your PCS account on the site, then go to the download section, you should see this:
With CCC you can choose the Entertainment profile and also adjust your fan curves so you can get lower temperatures.
I don't use CCC but I used ThrottleStop to undervolt and reduce CPU temps.
djsubtronic
I also get around 82 C on the GPU in some games. If I use max fan it usually stays around 79-80 C. You can enable max fan by pressing Fn + 1.
For the CPU 85 C is ok.
Emo
However, I have temperature problems on the CPU, with 50% use the temperature comes over 85 ° C.
It sounds like your windows isn't configured, all the fan profiles won't be working properly until you have windows configured so temps will be high!
Emo
That is?
Fans ramp up as temperatures rise. The problem is that the GPU drops by T while the CPU doesn't.
barlew
Godlike
If I were you I would do a full clean install of windows from a USB pen. Then run windows updates until there are non left. After that install Control Center and any missing drivers highlighted in device manager from PCS.
Then give it a go.
I think @SpyderTracks is right your windows isnt configured correctly.
Emo
Then give it a go.
Ok, I've done everything already (I'm working on a clean system).
What do you mean by "your windows isnt configured correctly"?
Emo
I installed Windows 10, then the clevo drivers, new Nvidia drivers, updated the Intel ones.
what drivers are you referring to?
thank you
thank you
All of them.
Windows 10 is very different to previous OS's.
You allow windows update to install all drivers it can, then only install any remaining direct from www.clevo.com.tw, not from your PCS downloads as they'll be out of date.
Then you just manually install NVidia drivers direct from nvidia, the full driver download, you don't install them through GeForce Experience.
Then lastly, you install the driver manager as that has to have all drivers correctly configured before it's installed or you'll find a lot of things won't work correctly. This would be Clevo Control center, again, you install this direct from Clevo.
And also, did you delete all partitions before installing windows?
Emo
ok.
i installed windows 10 clean in deleting and formatting partitions. Nvidia drivers I got them directly from the Nvidia site. the clevo drivers instead no, I used those of PCS. Win10 always up to date
You don't want to format anything, you just delete all partitions and install to the clean space.
Again, you let windows update install all it can first. Then only manually install the remaining ones from clevo.
  • Like
Reactions: Emo
Emo
Yes, I have not formatted and I leave it to Win10.
What I was missing were the Clevo drivers directly from the supplier.
The problem is:
I sent an email to Clevo.
